stone gravel driveway
  • stone gravel driveway
    I have always had trouble with certain materials. I am trying to map in a blue stone gravel driveway and it always tile horribly. Are there any tips or tricks that you guys use to create such materials?
    Thanx
    Eric Camper
    Studio 3D
    www.dbfinc.com/studio3d
    usually to remove tiling effect, you need to mix several maps with a procedural map.
    What you can try is mix two tilied textures, with a procedural noise map to blend them. Or, you may try a more advanced approach where you can use falloff map to specify camera disatanec and use the falloff map to blend between less tiled map at far and more tiled map at close up, thur redusing tiling effect. Such method is used in games, like half life 2 for example. However if you are using displacement this may not work.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      hmmm... detail mapping? isnt it?
        Great....YOu see....I have never really had a chance to do some of the more "detailed" stuff, due to just nat having the time to learn some things.....I usually just blended everything in PS later on.....I know I am gonna regret this ......What is detailed mapping a term or are you making fun??
        Eric Camper
        Studio 3D
          Eric, I find that vray displacement sometimes works great to hide tiling. Also gives a good roughness to something like gravel. At the expense of render time though.
          "A severed foot would make the ultimate stocking stuffer"
          -Mitch Hedberg
            I agree with powerandrubber. 2d Displacement with a crisp noise map (high/low thresh. about 0.6/0.4) or maybe a cellular map, can provide a quite convincing gravel texture. And to further enhance the gravel realism I sometimes add a physical noise modifier to the gravel geometry.
            "Why can't I build a dirigible with my mind?"
              never thought of that....Just made some changes and shall post the results...Thanx all
              Eric Camper
              Studio 3D
