Unrecoverable Crashes
  • Unrecoverable Crashes
    I've been having quite a few unrecoverable crashes. I can't seem to replicate it, but it happens after applying a diffuse map to a vraymtl, rendering (with gi) and then right clicking the diffuse slot on the material and hitting "clear"...
    Any ideas? Max closes, asks if I want to try and save the scene, and I hit ok, and it says "Recovery failed" and I lose my work.
    Specs: Max9 32bit// RC3
    UPDATE!!!!
    Reproducable: across several machines
    Do this:
    -open a new scene
    -open material editor
    -create a vraymtl in any slot
    -assign any bitmap to the diffuse slot of the vraymtl
    -check the visible in viewport checkerbox to make the diffuse appear in the viewport
    -go up one level back to the vraymtl level
    -right-click the diffuse 'm' and click "clear"
    Max will hold for 2seconds and then crash giving you an unrecoverable error
    Vray or max related?
    -Colin
    Colin Senner
    reproducible on max 9 but fine on max 8
      sound like display problem with max9 and vray mtl
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
        just tried exactly as you said but cant reproduce the crash.
        max 9 64bit/vray 64 bit
        www.boxxtech.com
          It is reproduceable on the 32bit versions of max 9 and vray rc3
          Colin Senner
            This is a problem in 3dsmax 9 specifically and happens because of changes in the 3dsmax SDK. It should be fine for newer builds.
              many thanks, it was just very annoying today when I lost 20m of work.
              -Colin
              Colin Senner
