VRayBlend Material limitation?
  • VRayBlend Material limitation?
    Just found that the Vrayblend material doesnt like a top/bottom material as the base material.
    Is this a limitation? or a bug?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
    VRayBlendMtl can work only with V-Ray compatible materials, since it uses V-Ray's own internal shading API rather than the 3dsmax one. So it will not work with the Top/Bottom material right away, but you may be able to simulate that with another VRayBlendMtl and a suitable blending map.
      But VRayBlendMtl doesn't work with VrayLightMtl...
      And it's not easy to build some simple mask pass...
      any idea
      My Flickr
        From spot3d helpfiles
        VRayBlendMtl is specifically designed for the V-Ray shading API and can only support V-Ray compatible materials (VRayMtl, VRayFastSSS etc). Additional V-Ray compatible materials can be developed with the V-Ray Shading SDK.
          smartarse
          Chris Jackson
          Shiftmedia
              are you sure? I've used the VrayLightMtl in a VrayblendMtl, although not as a base material.
              I find it 'quite' a useful way of generating a self illuminating material with vray. Or realy just making it brighter....
                I use blend material as a blend max material...
                I use it as a sort of maya's layerShader
                I prefer using only vray stuff into my renders... instead of max stuff... It's an old habit from maya + MR stand alone...
                Here is an example without color correction:
                http://www.kdgnet.net/demo3D/Fabien/...stCoupe002.mov
                Here is an example with color correction:
                http://www.kdgnet.net/demo3D/Fabien/...stCoupe003.mov
                I use a vrayBlend for the teeth shader...
                And for colour corection I need some mask to calibrate each material separately...
                Thats why I override with a max blend to have self illum colours...
                Best regards
                Edit : Sorry the second link was wrong... Now it's fixed...
                My Flickr
                  Well, it does, in newer builds which you can get if you email me to vlado@chaosgroup.com
