invalid bump normal
  • invalid bump normal
    hi there...
    it seems not a major problem, but V-Ray message window returns a bunch of warning messages, every time I'm rendering.
    warning: Texture "foam_def" returned an invalid bump normal (XYZ 1,#QNAN, 1,#QNAN, 1,#QNAN).
    warning: Invalid bump normal
    Anyone an idea, what might cause these errors?
    --> http://www.tobyatwork.de
    --> http://www.scriptspot.com/blog/toby
    What kind of texture is it?
      It's a procedural one.
      Here's an example-file with that material included (no such error occurs in this scene afaik), but I didn't change the values within the scene that I'm not allowed to show at this moment.
      --> http://www.tobyatwork.de/3d-worxx/ex...ean-shader.rar
        Are you using displacement? I have gotten that message before when using displacement which causes geometry to intersect each other.
        Tim Nelson
        timnelson3d.com
          This can also be from missing UV Mapping or Smoothing missing,
          Add a UV map Modifier (then render) and then a Smooth Modifier (then render) and see if it goes away.
          Cheers
          Mike K
          Two heads are better than one ...
          ....but some head is better than none.....
            I'm not using any displacement in that scene, but gonna check if uv-mapping is applied and whether the error goes away with having uv-mapping on or off.
