this is the result with your values DaForce (we were already using World and flythrough) but i have switched the other options.
what do you think?
of course i have to make all the irr map calculation (for the 450 frames), otherwise there's no problem. If i make a 50 frame or less part it's ok. The problem comes when it's for all the animation.
i still think u need more samples in that LC...
personally i ve ditched flythroug mode on animations to calculate each nth frame in order to have more control over it...
did you try raising hemispherical subdivisions as several people have already suggested?. Also the frame looks very blurry so i think 40 is too high for interp samples. id also raise your max rate from -3 to at least -2.
Other than that, its most likely lightcache settings as mentioned I think (more subdivisions)
3000 subds on LC with world in me always gives max crash for not enough memory (2GB on 4800x2 with double fast hdd in RAID)
COuld u please tell the reason ?
Is it better to raise up radius from 0.02meters to something like 0,.05 to avoid crashes?
thanks in advance
