On one of our farm machines, which is set up more or less the same as all the others, when doing a distributed render the Vray Messages box says Server 192. etc: Starting Frame 973569 (this number changes every attempt, but is always huge). Then the next line is correct : Starting Frame 0, but it keeps repeating this line and doesn't render. It will work correctly as a regular network render. Does anyone have any idea of what I can try to check out?
Distributed Rendering Problem: Spurious frame Number
Yes, the machines are a mix of 64/32. I think that I solved the problem by reinstalling the service. But I'm unclear on whether or not the services are different depending on whether you install from the 32 bit or the 64 bit version. There appears to be only one and they appear to be the same, but I haven't had a chance to test this yet. If they are different this could perhaps be the problem that nikki Candelero is referring to. If anyone knows anything about this, I'd appreciate it. I'll post when I get more information on this topic.
--ds
The demo is watermarked so it will do you no good, but you can email me to vlado@chaosgroup.com
VladoI only act like I know everything, Rogers.
