MAX or Vray viewport bug continued
  • #31
    Originally posted by BiTcH
    difference of price is justified with language translation....................................... .. btw i work with an english version and i love it
    Me too, anyway, english uk is twice the price than us version. Us license is not valid in Europe
    Philippe Steels
    Pixelab - Blog - Flickr
    • #32
      u right !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! btw an autodesk guy told me all can be negociated with autodesk ......mostly if you work with architects you are a kind publicity for them..
      • #33
        the backward incompatibility of maxfiles is just crazy....
        teabag studios
        www.teabagstudios.com
        • #34
          You mean... juicy
          Philippe Steels
          • #35
            it is, really................... just to make you buy upgrades...................
            one day we won't be able to upgrade hardware and software ...
            • #36
              Martin
              Check that your model is not too far away from 0,0 point. If any part of your model is like 2000000 units from 0,0 you'll have this problem.
              When importing spllines from CAD i always apply an edit-spline modifier which in effect resets the splines's bounding box.
              View your model in box mode and that'll tell if you have any of these problems.
              BTW I had simmilar problems with sketch-up as well
              Another thing. I aggree that MAX is waaaaaay overpriced.
              Hope this helps
              Z.
              • #37
                thanks for the tip zoranm...willl try that today
                teabag studios
                • #38
                  Hi there, realise this is an old thread....
                  I've had this problem loads. I'm pretty sure it's a unit's problem. If you always work in metres and convert any units of incoming CAD files upon importing, you'll be fine. I think it links in the with 'resulting accuracy' problem max has always had. Which is why 'user' view displays everything fine and 'perspective/camera' views look weird. If you zoom right out it should also look ok.
                  • #39
                    I have always found Max's shaded view port crappy when compared to lightwave, Maya or any of the other packages.
                    Thats just me though.
