strange corners
  • strange corners
    hi there
    i encountered some weird artifacts in my latest renderings (you have to zoom in the image to see it better).
    this may look like a D.E. problem, but could'nt figure it out yet.
    has someone had this problem before?
    is there a solution? have already done a search on the forum.
    i'm running Max9 (P.Booster) on XP64 and Vray 1.5RC3
    thanks in advance.
    ale
    [img=http://img19.imageshack.us/img19/8378/strangecornersws8.th.jpg]
    ____________________________
    www.indivizuals.ch
    Are you using DE? have you tried just turning it off and seeing if it renders ok?
      I think the solution - is to rise irrmap settings to smth like "high".
      I just can't seem to trust myself
      So what chance does that leave, for anyone else?
      CG Artist
        heheh I always find it funny how the only word you abbreviate Paul is something.. smth.. hahaha
          thanks guys...
          it has nothing to do with DE so far, as the problem persists.
          the irrmap is already quite high (-3,-1, HSPH60, IntSp. 20).
          it's the bump on the wall that causes those strange spots.
          when i disable the bump, they're gone.
          how can i still have the bump on the wall without those annoying artifacts?
          is there some workaround? have i to use a normal map instead of a bump-map?
          thanks for further help.
          ale
          www.indivizuals.ch
            I love these tiny small thingies
            CG Artist
              What exactly troubles you about the images? The "Noisy" look can be reduced if you increase the bump map size or decrease the bump map strength.
                hi vlado
                here are two pics that show the problem i mean.
                there is seriously some kind of bug with the bump, as when i remove it,
                the problem's gone. never had such weird results in prev. versions (1.47.03) and there isn't any kind of modeling issue.
                thank you
                ale
                www.indivizuals.ch
                  please post your render settings.
                    now that was fast =)
                    ok, here are my settings for a target size of 1754 x 1240.
                    www.indivizuals.ch
                      Hmm your LC info is missing, could you provide that as well.
                      Having not used DE much myself, you have set the radius to 20CM thats seem way to big to pick up any detail. I would suggest dropping it alot. Try 2-5cm see if that makes any difference.
                      I could also be releated to your LC.. but unlikely.
                      <edit> scrub that.. just read the info on it and it seems to be the opposite of my thinking.. heck try it anyway. lol
                      If you could try with DE off as well that would be great
                      See how in the bottom of the last larger image that you posted.. there is clear circles down there. That would be either the DE or LC I believe. *just a hunch*
                        oups, missed that with the LC, here it is.
                        i'll try without DE.
                        thank you DaForce for your time.
                        www.indivizuals.ch
                          ok here we go.
                          Is this for an animation? if not switch DE and LC back to screen (for their scale). In LC untick the following to be safe, "store direct light" "adaptive tracing" and "use directions only"
                          Also your filter size needs to be lower. general rule of thumbs is keep it around 4x your your sample size.
                            okey, seems there are plenty of things i did not get yet.
                            these settings are for stills, so i'll stick with screen mode.
                            i'll report the results.
                            thank you again =)
                            ale
                            www.indivizuals.ch
                            • #15
                              Not a problem
                              Let me know the results.
