I'm using max 8 and RC3 with the dongle. It works fine for awhile, then it looses the license. Anyone have any ideas? My max license seems to be timing out too....it never did this before the dongle. I'm thinking they are related. Any ideas?
Dongle and license issues
I can't comment on the 3dsmax license thing; the dongle is not related to it in any way, as far as I know.
As for the V-Ray license being lost, the first question is if you are running the license server locally on the same machine, or on another machine in the network. If it is the second, then this can happen if for some reason the machine fails to connect to the license server, and the server flushes the license.
Once a machine is connected to the license server, it will periodically (about once in 30 seconds) ping the server to see if it is still there. If the license server does not receive a ping from a machine in about 1 minute, it will free the licenses taken up by that machine. However if the machine is still running, subsequent license requests from it will fail.
What you can try, is the next time when you lose the V-Ray license, open the license server web page and see what it says there (e.g. if it lists your machine as connected to the license server or not). If it is not listed, then you can email me to vlado@chaosgroup.com and we'll try to work around this.
VladoI only act like I know everything, Rogers.
Originally posted by DaForceany software based firewalls on your pc or the one with the dongle in it?
Try shutting those down and see if it helps.
Originally posted by vladoAs for the V-Ray license being lost, the first question is if you are running the license server locally on the same machine, or on another machine in the network. If it is the second, then this can happen if for some reason the machine fails to connect to the license server, and the server flushes the license.
Another thing I forgot to mention is my computer will no longer participate in network rendering via backburner. I've got 60 other computers that do fine, but the computer I use all day long just errors out and says "[V-Ray] Could not obtain a license"
thanks guys.
Originally posted by vladoWhen it does not work, is it possible that you have another copy of 3dsmax running somewhere in the background (e.g. if you check the Task Manager)?
Well, if you wish you can email me to vlado@chaosgroup.com and I'll get you a newer build that hopefully works better.
Originally posted by vladoWell, if you wish you can email me to vlado@chaosgroup.com and I'll get you a newer build that hopefully works better.
