I'm having some trouble with PArray's.
Working with Max 9 x64, rev3 and vray 1.50.00.
There's a known Max-bug regarding the PArray Rate not working, but having some other trouble with it as well.
1. Sometimes when the PArray isn't shown in the viewport due to complex scene or redraw-issues, then it won't render either.
2. The Viewport display percentage affects the render, ie if set to display 10% it will only render 10% as well...
3. And finally, when using DR the PArray's won't be rendered by the nodes, only by the host.
Anyone know a solution or workaround?
EDIT: When tried to recreate this in a new scene, i only imported the PArray's and the base geometry for particles and emitters, i had none of the above mentioned problems... so i guess it seems to have to do with no.1 - complex scenes
