Loosing VRay License Please Help !!
  • Loosing VRay License Please Help !!
    We are experiencing problems with staying connected with the VRay license servers. We are using VRay 1.5 (and Max 8-sp3) with the 3 dongles. Currently two people are using the dongles locally while the third dongle is being accessed through the network for the other 3 licenses. In each instance [local and network], we loose the license after a period of time. We have tried several things already to help narrow down the cause of the problem, but have run out of ideas. This includes:
    - Forcing port 30304 to be open in the software firewall for all traffic on the subnet [I believe this is the correct port for the license server].
    - Making McAfee anti-virus not scan anything in the Chaos/VRay directories
    - Disabling McAfee Anti-virus.
    - Disabling the software firewall.
    - Running the license server as a service
    - Disabling the service and running the license server via double clicking the exe file.
    One instance that happened recently is that I was creating textures, but I hadn’t rendered anything. When I was almost done creating all the textures, I lost the license because all the sudden the material previews disappeared and it was all black. It also happens when we are doing test renders to check textures and lighting [i.e. after several test renders, the license will be lost]. I have noticed that when I look at the status of the license server [on all 3 servers], I never see licenses being “engaged” but do notice that some workstations are connected via the sessions list. Don’t know if that means anything.
    Is there a time limit that the licenses can be used and then need to be refreshed? If so, can we extend that time limit somehow? If no, can there be a button within the render dialog box that “reconnects” to the server without restarting Max?
    If you have any ideas of what could be causing this, please let me know. Thanks.
    When this happens, do you notice a delay at the start of the rendering when V-Ray tries to obtain a license? Or it directly reports that no license is available?
    Also, can you contact me directly to vlado@chaosgroup.com and we'll try to work around the issue.
      I am having the same problem, only on 1 computer
      If I use "ctrl alt delete" and wait 5 seconds, the problem is solved for the time being.
        Would it be possible to contact me directly to vlado@chaosgroup.com so that we can work on solving this issue?
