Photometric Lights in VRay 1.5
  • Photometric Lights in VRay 1.5
    I'm working on an interior scene at the moment and I used some Photometric Linear lights. I had to set the intensity of these lights to 4000 lx at 2000cm to get a bit of a result, while in the past, 400 lx at 200cm was enough.
    Am I missing something here? I'm using the VRay 1.5 settings for the Sun/Sky and Camera. Could it be that I have to check the "Use 3dsmax photometric scale" tickbox?
    I've searched the forum but couldn't really find anything about it.
    -edit-
    Setup:
    Max 9 32 bit, VRay 1.5
    -edit 2-
    The same goes for VRayLights by the way. A multiplier of 1.000.000 (!!!) starts to give a little result!
    www.artbyarjan.com - Online portfolio (temporarily offline)
    @home:
    / AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
    / Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
    @work:
    / Intel Core2Quad Q9450 @ 2.66Ghz /
    Nvidia Quadro FX 3700 / 8Gb Ram /
    / Vista Bussines x64 /
    What is your system units scale? Are you using the V-Ray physical camera or a normal camera?
      System Unit Scale is millimeters
      Display Unit Scale is centimeters
      We're using Physical Cameras
      @home:
      @work:
        Then you should check the "Use 3dsmax photometric scale" option, yes. You may also need to adjust the camera parameters (f-stop, shutter speed, film ISO).
          Where can I find, this check box?... I use rc4.
          another question is the sky intensity in rc4 correct?
          Best regards
          ern
