Vray Render Elements & Render Pass Manager (RPM)
  • Vray Render Elements & Render Pass Manager (RPM)
    Is anyone here using RPM in their workflow?
    I can't get RPM to save out vray elements when using the vray vfb, but it works fine with the max vfb.
    Any ideas?
    Cheers,
    Olly
    Set V-Ray class properties en masse with the VMC script
    Follow me for script updates: @ollyspolys
    Yes, we have the same issue with our in-house render manager
    Eric Boer
    Dev
      I think you might need to speak with grant about that.
        No, it is V-Ray. When the V-Ray framebuffer is enabled it does not save extra channels through backburner. I thinks someone else was having an issue when the elements were being explicitly named in the elements rollout.
        Eric Boer
        Dev
          oops my bad, misunderstood what you said. I haven't sadly been able to use rp manager since moving to new employer.
            So is there a way around this?
            I want to avoid creating & rendering an additional set of passes to save out the element data, especially when it's already been calculated on the beauty pass. Seems to be a bit of a step back to me...
            Any thoughts?
            Cheers,
            Olly
              Just do not enable the vray frame buffer and it will work
              Eric Boer
              Dev
                In the element settings or the vray vfb rollout?
                  I'm not sure exactly how it is set up in RPM but the vray vfb needs to be disabled and the elements just used normally.
                  Eric Boer
                  Dev
