strange camera issue ?
  • strange camera issue ?
    Hello friends !
    I am not sure what I am doing wrong, but this is my viewport:
    there is clearly to see a red box, and that the plane is not flat, it's a wave form now, so it will fit to the building.
    And here is the small render preview:
    well, where is the red box ?
    Why is the plane, just flat and not like it is in my viewport ?
    what's going on here ?
    I must do something wrong, but never had this issue before !!!
    I use Vray Sun & Sky, with vray cam....
    thx for every little help,
    bernhard
    www.bernhardrieder.com
    rieder.bernhard@gmail.com
    Do you have a vrayplane in the scene?
      no
      I do have a standard plane, and on top an edit poly modifier, plus turbosmooth...
      I need to use and editable poly, because I need geometry to model.
      So I get the right surface....
      thx,
      bernhard
        Ofcurse, an editable poly should work perfectly fine.
        The render looks like it has a big plane crossing at ground level thus the vrayplane question.
        Some more sugestions: do you have turbosmoth with 0 iterations for render and the edit poly on top of it? Have you tried to do some isolate renders to find if there is any problematic object? Can be a displacement problem ? (Sometimes I forget the default max displacement cheked and get weird geometry...)
          I seem to remember a bug that a hidden vray plane didn't actually hide but it's been a while since I've seen that happen and I know it doesn't do this in the latest vray version.
            hmmmm
            well, i's not a vray plane...
            i could find out, that that the turbosmooth modifier caused this problem.
            I've checked it with a new camera, same problem.
            for the rendering, I use iterations 2, like in the viewport.
            I could fix it, in collapsing all together...
            hmmm, but weired...
            thx,
            bernhard
