Odd Glass problem
  • Odd Glass problem
    Hi All,
    never had this before, and im sure im missing something obvious but what??
    Problem is this...
    cannot get light though a simple box/glass shape.
    see left and right of image...
    mdi-digital.com
    What if you check the "Affect shadows" option for the glass?
      no change
      mdi-digital.com
        what happens if you set your diffuse to white?
          no change..
          I even rebuild the window glass with a new object, and the problems still there
          mdi-digital.com
            ok....i think it might be a scale problem or somthing...see attached...
            once I move the window outside of the wall eveything seems to work ok..any ideas?
            mdi-digital.com
              In the V-Ray indirect illumination settings, do you have "Refractive GI caustics" on?
                it was off, but I turned it on....made no difference.
                heres a quicktime to better illustrate the problem
                http://www.mushroomgod.com/glass.mov
                mdi-digital.com
                  Well, I'm all out of ideas then; if you wish you can send me just that part of your scene to vlado@chaosgroup.com and I will be able to tell you more about why this happens.
                    woot....figured it out..
                    It was todo with the vray sun, I deleted it and put a new one in the scene and it all working now!
                    Very strange though
                    mdi-digital.com
                      nope...forget that last post...ill email over the scene to you vlado
                      mdi-digital.com
                        Just to clarify you need both refractive GI caustics AND affect shadow on for it to work.
                        You may have missed the right combo for it to work.
                          i fixed it, not sure what the problem was...im sure it was all my own doing though, clicking this, clicking that.
                          Anyway, I merged it into a new scene, and copyed a few settings and it seems to be working now
                          mdi-digital.com
                            be good if you can figure out what fixed it. i've got the same issue now...
                            • #15
                              oh...
                              All i did was to merge it into an older scene that was aready setup and working...then made sure my windows had the same settings (object/vray properties ) and bobs youre uncle it all worked.
                              But i dont really know if the problem was the object properties or the render settings....sorry
                              mdi-digital.com
