I have used the "Animation (prepass)" setting and have created 400 irmaps in a folder when I go to use them with the "Animation (rendering)" setting I select the irmap without the number (also have tried to use the one with 0000 as the starting irmap) and all the rendered frames come out as if the irmap was not included. If I change the setting to "from file" and select the corresponding irmap and frame number it renders correctly. Am I doing something wrong or what should I be doing?
Other notes about the file:
The irmap is 1/2 the size of the final rendered frame.
I see no errors come up while rendering with it set to Animation (rendering)
