Faces become Blue under Water.
  • Faces become Blue under Water.
    Hey Guys was wondering if i could get some help here i have a plane with a Water material and i keep getting some blue faces when theres an object under it. Dont know exactly whats causing this ive tried playing with the settings but no luck. Maybe someone can comment. Also keep in mind its only the objects close to the plane once they get lower the blue dissapears.
    Thanks so much.
    Ruben Gil
    www.spvisionz.com
    www.linkedin.com/in/s2vgroup
    Try having the water as a closed mesh, not a plane, especially if you use fog.
    I can't think of anything else...
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Secondary rays bias ?
      CG Artist
        tried it its still happening lol.
        Ruben Gil
        www.spvisionz.com
          Do you have any environment overrides?
            No
            Nope i have them at Default i even tried overiding them and using vraysky etc. but i get the same results.
            Ruben Gil
            www.spvisionz.com
              Would you mind posting a scene stripped down to the bare minimum, so to have a look at it?
              Lele
              Disclaimer:
                sure
                yea sure give me a sec! thanks for the fast response!
                Dude my ftp is down right now i cant get it on. anywone know any free file sharing services.
                Ruben Gil
                www.spvisionz.com
                  depositfiles.com
                  rapidshare.com
                  furk.net
                  sharebee.com
                  megashare.com
                  CG Artist
                    lol
                    Lol Thanks O_o
                    here ya go...
                    http://rapidshare.com/files/77930587...ipped.zip.html
                    Ruben Gil
                    www.spvisionz.com
                      Well I have had a quick look, and its certainly the fog thats causing it. If you turn it off the problem goes away.
                      Even with default vray materials on everything and using just brute force GI some parts of the mesh are bright blue. I even put in a few teapots and boxes and some of those get affected as well.
                      Even placing a single plane over the objects does the same thing.
                      Also happens with just a direct light for the lighting. And even after clearing up the vraylog errors.. it still happens.
                      Im just a little stumped.
                      Certainly is to do with the fog...but why.. bug... Vlado?
                        I took a look as well and came to the same conclusion daforce did (a bug?). Only thing I can add though is that you can control the "depth" of the blue surfaces by adjusting the shadow bias, which was at .2m which translates to 7" which I think is too big (for me it's normally .2"). Adjusting it to .005m clears up most of the blue but it is still there in a few spots.
                          I find it realistic though, if you stay enough time underwater sure your face will turn blue too.
                          Sorry, couldn't resist
                            But then the blue faces would be down at the bottom of the pool since you'd sink
                              Look at the posted image, the bottom is pale blue as expected
                              k k, thats my share of morbid humor for today
