Remote Dongle
  • Remote Dongle
    When I connect remotely to check my image I cancel, tweak, and hit render again. When I do this remotely the Dongle isn't located. The dongle is on the machine I am connecting to via the web. What would cause this? I can go to the physical machine and hit render and it works just fine.
    Frustrated and will miss my deadline tomorrow
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Looks like you have to head back to work Bobby?
    Sorry bud,
    Colin
    Colin Senner
      back to work
      and to work I went...spooky in here!
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        This is a longshot, but it might work. It could be an IP conflict.
        I assume you mean that you connect to your work PC through VPN?
        Do you use the standard Windows connection or a special program?
        In the first case you could check if you have the following option checked or not.
        Like I said, I don't know if it'll work, but you never know...
        www.artbyarjan.com - Online portfolio (temporarily offline)
        @home:
        / AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
        / Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
        @work:
        / Intel Core2Quad Q9450 @ 2.66Ghz /
        Nvidia Quadro FX 3700 / 8Gb Ram /
        / Vista Bussines x64 /
          Remote
          I use logmein, which is a web based product that gets me in via the web. I am running xp 64 with a cisco router and cisco doesn't support VPN for 64. Anyway, I figure it out. It seems when I have the hardware lock in my monitors USB port it doesn't work remotely. When I have it plugged into my machine it is fine. Very strange.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Have you tried HAMACHI from the people who make LogMeIn? Its a very nice easy to setup VPN
