I have this file...It has some xfrog plants that I have proxied after I kept crashing a little here and there. It isnt as big as any other file I have ever worked on. Is there a log file that I can look at to see what is happening. Thanx all
max crashes...gone...bye bye
max crash
I am having the same issue, odd.... I was working along fine, did a saveas, crashed! I had to collapse everything for my render to work. I opened the original and the same thing. Collapsing is the only thing that works for me when this kind of thing happens. I am now going to look for backups.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
Eric... yeah its called the vraylog.. and can be found in the root of your C drive.. so in c:\
That "may" give you some clue as to why its crashing.
Have you watched the memory usage during the renders.
And also make sure to turn off filtering or turn off the bitmap blur for the opactiy maps for those leaves, will render alot quicker and look much better.
yup...Where is the bitmap blur thing....Oh....Do you mean Blur and Blur offset? They are set to 1.0 and 0.0.Last edited by EricCamper; 17-01-2008, 07:10 AM.
