max 9 64 bit and vray 1.5 sp1
send me a file if you want, and I can have a look.
I am using max 9 64bit and sp1 and have had no problems.
Thanks! The file is quite big right now 50 MB. I'm doing some more testing to see what could be the problem and if the same thing happens if I delete all the people, trees, etc. It definitely cannot be a problem with bitmaps and paths, otherwise the same thing would happen at low res. Though, there is something I have always wondered about......If from the beginning when you create the material all the bitmap paths are mapped in a way that all the render nodes find the bitmaps, what is the use for the "customize bitmap paths" under the customize menu?
Well, I deinstalled all the old copies of backburner and vray for max7 from my computers. Now there seem to be only (2) render nodes that give me problems......and I do not get it. Using my computer and the (2) problem render nodes I get this result:
If I render the same file directly from those (2) render nodes, the scene renders fine. The materials are rendering....it just seems to be the HDRI environment map that is not showing up.
i told u already in ur other post...i bet the problems u are experiencing are network configuration related!
what s ur server OS?
there are several of threads wich claim the same problems and in the end most of them are network related...either way i got it working here flawlessly, as many others do, that should be a heads up by itself,....me thinks
were are the bitmaps and the gi saved into? the server?
