Remote Dongle connection
  • Remote Dongle connection
    Is it possible to borrow a remote Vray license via a dongle? I have 3 dongles here and a fellow team member wold like to use one while he is offsite? Is there a way I can forward a port or something and have him enter my IP address and port setting through his Vray server?
    Using Max 2008/32bit on Windows XP SP2
    thanks in advance
    ___________________
    joel lelievre
    www.intrinsia.net
    www.delicatemachines.com
    You can do that; the port used by the license server is 30304.
      If I can access the license current status by http://mydomain.com:30304:getstatus
      How should I write that adress in the "Change V-ray client license settings" on my workstation?
      I tried http://mydomain.com:30304 but it didn't work so I guess I need to change someting. What?
      (I'll never get a job as Admin)
        I believe you need the underlying IP address, rather than using the URL. So in Vray you'll enter, for example: 111.101.202.185
        You have to find out what your 12 digit IP address actually is.
          Or, vpn works, too.
          Bobby Parker
          www.bobby-parker.com
          e-mail: info@bobby-parker.com
          phone: 2188206812
          My current hardware setup:
          • Ryzen 9 5900x CPU
          • 128gb Vengeance RGB Pro RAM
          • NVIDIA GeForce RTX 4090 X2
          • ​Windows 11 Pro
            ok I'll try that. I figured my idéa could work as the asus router has a ddns feature.
