Shadow
  • #31
    settings
    I am trying it, but it is crawling.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    • #32
      just back to the the image taking 15 minutes. To avoid wasting time trying to figure out what the cause is i think that its better to just go with the slow high settings and have it take 1 hour to render. My prelim renders take 4-12 hours and much of it may be overkill but then it saves having to worry about issues such as lighting quality & shadows etc. anyway, just my personal preference
      • #33
        I've always been wary of altering the irr clr thresh; well, all of the options on the right side under the basic parameters for the Irr map. Hrmm.. I guess I'll have to start playing with them on my next interior scene.
        • #34
          Shadows
          Someone suggested doing an ambient occlusion, which I did, but my ceilings and walls are 100% black. My materials for my ceiling and walls might be the issue. I am using the same material, changing the diffused, for all my walls and ceilings.
          I'll investigate and report back.
          http://www.whitebirchstudios.com/pub...0occlusion.png
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #35
            Shadows
            The odd part is the center part of the fireplace was the wall material then I changed it to a tile. The last post on the railings is using the same material as all the other railing members. What could be going on?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #36
              Your normals are most likely flipped.
              • #37
                normals
                That was it. My normals were flipped. There should be a way to show an arrow pointing in the direction of your normals.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #38
                  You can display the normal vectors for selected faces or vertices by enabling Show Normals on the Selection rollout of an editable mesh object or the Edit Mesh modifier.
                  • #39
                    Normals
                    I knew you were going to say you can , but I spoke to soon. It isn't the normals causing the issue. The hunt is on.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #40
                      Double faces
                      I had double faces going on! I have to stop working so late. You can usually tell when you have double faces in your render, but I didn't see it until I did the ambient occlusion. Thanks for all the help. Hopefully someone else can learn from my idiotic antics.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
