new install error
  • #16
    Here are links for the Microsoft Visual C++ redistributables (these are included for 3ds Max 2009 by the way, so no need to install them if you have it):
    32-bit version: http://www.microsoft.com/downloads/d...displaylang=en
    64-bit version: http://www.microsoft.com/downloads/d...displaylang=en
    • #17
      This is only for the vraysimbiontmtl90 error correct?
      • #18
        Yep, this is correct.
        • #19
          Any idea how to fix the vista issue?
          • #20
            Did you run the install as an Admin? Are you running Vista Ultimate with Superfetch enabled?
            Eric Boer
            Dev
            • #21
              I've tried the run as admin with no luck. I'm using Vista business. No clue what superfetch is so I'll be looking into that today.
              thanks.
              • #22
                Should i install the Microsoft Visual C++ update, on all render slaves too????
                • #23
                  This is what worry's me .. i think so yes ..
                  Natty
                  http://www.rendertime.co.uk
                  • #24
                    Natty
                    you shouldn't have soo many nodes then.....should you!!!!
                    Only messing...i'm just jealous hehe.....sounds a pain if you have to do it to all of them tho.
                    I seem to be having problems with DR.....its strange, the vray message box says the scene has been loaded fine to render nodes, and says it has started rendering....but no extra buckets appear????? If I restart all the spawners, it works again......I thought initially that it was when I restarted my main workstation (hence restarting the Vray license).....now i'm not too sure....seems like spawner fails randomly at the moment....when usually it was soo reliable.
                    BTW I use MAX 9, 64 bit......DR using Irr Map + Bucket Mode
                    Lewis (pacific)
                    • #25
                      Hey Matey hows things ... being worked to the bone! .. : )
                      well we have'nt installed sp2 as yet due to this problem, not sure what im going to do yet... could be a long weekend! but i dont wont to do all this work to find out something doesnt work..
                      have a good day mate and stop going on the forum! I will tell david
                      Natty
                      • #26
                        I got him under control....so i dont need worry hehe.
                        • #27
                          Thank you! Once I disabled superfetch it installed fine.
                          • #28
                            Cool, I had a feeling that was it.
                            Eric Boer
                            Dev
                            • #29
                              vraysimbiont90
                              Hello Vlado.
                              What does vraysimbiont90 do ?
                              • #30
                                It allows you to load darktree shaders
                                Eric Boer
                                Dev
