Max frame buffer is clamping my renders :P
  • Max frame buffer is clamping my renders :P
    Got one quick question:
    I'm rendering out an animation with Vray to 32bit full float RPF format
    Now when I bring one of the frames into combustion the Max framebuffer seems to be clamping the everything to 1.0
    but if I render out a still with the VFB then save to RPF with exactly the same scene/settings it bring the full float data into combustion perfectly fine.
    What am I doing wrong???
    You can try to set the "output_force32bit_3dsmax_vfb" renderer property to "true" from MaxScript and see if it helps.
      sorry I'm not very familiar with maxscript.
      How do I do that? I open maxscript and ran
      "output_force32bit_3dsmax_vfb" "true"
      but I got back a call error
        you need to add a '='
        In the listener simply type:
        Code:
        output_force32bit_3dsmax_vfb=true
        And hit Enter (Enter, not return )
        Regards,
        Thorsten
          Actually, it would be,
          Code:
          renderers.current.output_force32bit_3dsmax_vfb=true
          Bet regards,
