MotionBlur Problem SP1 max 2008 64bits
  • MotionBlur Problem SP1 max 2008 64bits
    Hello Vlado,
    We've got a problem with motion blur :
    With quick rotation I've got an annoying problem, First frame OK and second bad:
    Here the render setup:
    When I raise the geometry sample to 3 or 4 it's OK, but I've got a very big problem, a RAM problem, this scene goes to more than 12Gb... So I can't render it !
    With geometry sample set to 2 I've got a 5.7Gb peak. all the renders works with 4Gb !!
    It's a very huge scene (650Mb)
    The problem only appears with rotations, translations are ok...
    The only solution I found is to raise the geometry sample by object to 3 or 4 to avoid RAM consumption, my render to failed or to take a very long time to achieve....
    So is-it a bug or is it normal???
    I can send you a sample scene if you want to play with...
    Best regards...
    PS: I had no time to test it with SP2 and no time to reproduce with a simple scene... at the moment...
    My Flickr
    Here the link to a simple scene with the problem.
    http://www.digitalsoap.ch/le-truc/Vray/Test001.zip
    Frame 92 ok, frame 93 Problem
    With this part(element) I need to raise sample to 8 or 10 to avoid problem...
    Please help !!!!
    Best regards...
    My Flickr
      One more think about this scene...
      When I use a simple vraylightMtl with full red or any color... there are no problem at all....
      I' don't known if I m very clear about that... My English sucks...
      When no shading no problem
      Best regards....
      My Flickr
        Hello Guys,
        I try SP2 and no more Motion Blur problem...
        Same scene setup and no problem...
        Sorry for triple posting but this problem cause me pain
        Best regards...
        My Flickr
          There was a particular issue with motion blur in sp1 that is fixed in sp2.
