ExtraTex and MtlSelect Passes
  • ExtraTex and MtlSelect Passes
    ExtraTex renders the texture onto matte objects
    MtlSelect doesn't use material in slot when render settings are merged even if a material with the same name exists in the scene.
    --Jon
    Jon Reynolds
    Method Studios
    Matte Pass
    I am not sure I understand your post, but have you tried this script?
    http://www.scriptspot.com/3ds-max/rendermask
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
      Thanks Bobby , always good to keep up on the latest free scripts and I did not know of this one I'm referring to two VRay Render Elements that are not acting ideally.
      When using the "ExtraTex" element I am getting an output of the extra texmap I've defined applied to all objects including matte objects that I would like to be rendered a RGBA =0,0,0,0
      The "MtlSelect" is used to define a shader to apply to a pass. In my case I'm using it to extract a certain level of a shader tree so it can be controlled in comping. When I use render presets which brings in my render elements setup the shader that is referenced in that element is not present... or something???? and renders black unless I reconnect it each time.
      Hope that explains what my problem is better
      --Jon
      Jon Reynolds
      Method Studios
        Hm, is this bad Maybe someone would need this... otherwise I can probably add an option to skip matte objects when calculating the texture.
        Nothing much to do about this, I am afraid. When merging the render settings, 3ds Max simply creates a new material for the MtlSelect - it does not look in your current scene to find a material with the same name.
          You know I guess it really isn't that big of a deal now that you point it out. I was just doing some QA and expected it to be consistent with other passes but now I notice that the matte objects are considered in the alpha so come to think of it...
          It will all work out in the comp
          Yeah I kinda figured this was the case. We should be able to custom fit a workaround into our pipeline.
          Thanks for your time
          --Jon
          Jon Reynolds
          Method Studios
            Should be easy enough provided the material has a correspondent, and unique, material name in the scene...
            Lele
            emanuele.lecchi@chaos.com
            Disclaimer:
              So I've added an option "Affect matte objects" to the VRayExtraTex element now...
