Issue with animation mode of IRmap
  • Issue with animation mode of IRmap
    If I render this scene as a single frame with the IR map calculating at the same time, it renders fine.
    If I do a single frame IR map, save to file, and render from that saved one, it works fine.
    But if I render a sequence of IR maps to file with the animation mode, and then render one frame of the animation (even just using 'from file' mode), I get this:
    Which isnt good.
    Whats the difference between rendering the irradiance map single frame and animation pre-pass, aside from the sequential numbering? Whatever that is, my chairs dont like it. Theyre all vray materials too.
    What are the materials of the chairs? Also, what is the secondary GI engine set to for the final renders?
      The chair materials are vray materials - just bitmap within colour correct to add a tiny bit more contrast, spec & bump. Metal on them is as simple as it gets, dark diffuse and high reflection.
      The secondary bounce is brute force, 8 subdivisions and 5 secondary bounces.
        Hm, no immediate idea then, I will have to take a look at the scene. Have you changed object counts (e.g. hide/unhide) objects between the calculation phase and the rendering phase?
          Not at all - it is an xref though, could that be causing it?
          I've got my model in one scene, and i'm rendering from one which just contains lights/cameras and render settings.
            Ok, and what are your irradiance map settings (min/max rate in particular)?
              What's it look like if you assign an override material? Or tick the show GI only. Whatever helps isolate the problem!
                It's set to medium preset, 60/30.
                Combustion is just rendering at the moment so I cant open the scene, i'll edit all the other number in 12 minutes from now...
