error: Could not save irradiance map+backburner
  • error: Could not save irradiance map+backburner
    Hi all,
    I have a problem when calculating my Irradiance map through backburner.
    I use multi incremental mode with auto-save and i got frames that contain errors very often.
    an idea to solve this problem?
    Save imaps per nth then merge them together, it is pretty much fail proof.
    Eric Boer
    Dev
      zedish23,
      You can't send an irradiance map calculation to multiple nodes through backburner. The only way to take advantage of multiple nodes is to send frames 0-200 to node01, frames 201-400 to node02 etc. Then do as RErender says, merge the files at the end.
      Dan Brew
        I do not understand
        “Merge the files at the end” means using add to current map mode ?
          I think, i do not understand
          “Merge the files at the end” means using incremental add to current map mode ?
            You should have the Irradiance map viewer installed, go to Chaos Group in your start menu and look under Tools. You can merge them in that.
            Dan
            Dan Brew
              Many thanks for help guys. Is there any way to automate the process ?
                I think these still work http://varcht.net/index.php?option=c...d=13&Itemid=28
                Eric Boer
                Dev
                  thanks this should help
                    Ok, but why does Daniel say you cant do that ?
                    Regards
                    Steve
                    My Portfolio
                      Normally they would overwrite each other, without something like my script.
                      Eric Boer
                      Dev
