Problem with Sp3 on one machine
  • Problem with Sp3 on one machine
    Hi
    When starting up Max (2009) after I installed VRay Sp3 I get error codes for all the VRay plugins.
    Some have the code - 1073741795 (null)
    and others
    error code 126
    I am running XP 32-bit with SP3
    Hope to solve this soon.
    Thanks
    maybe the old issue with plugi.ini file, try to double check it
    Alessandro
      Hi
      I have been working some late nights lately so the brain is fried
      What exactly do i need to do with the plug.ini file?
      Thanks
        Here SP3 is working fine, but I can hardly remember that sometimes in the past there were some problems during the installation process and the plugin.ini file became a mess; so, simply double check that the LAST line is correctly pointing to VRay additional plugin directory.
        Alessandro
          Thanks so much for the quick replies!
          Sadly the problem is still here. I checked the plugin.ini file. All looked well. I even tried it with coping the plugin.ini file from the machine where it is working.
          Did not helped either
            There is another plugin.ini file in the local settings folder of the current user; check that one as well.
              Hi Vlado
              This second plugin.ini file, must that also contain lines related to VRay?
              Not one of the two machines has info on VRay in this plugin.ini file, although on the one machine the installation works.
                Yes, that plugin.ini file must also contain the V-Ray lines.
                  Thanks for the help so far, for now i have re-installed SP2 and will get back to this after Tuesday (deadline)
                    Yep, not a good idea to change builds in the middle of a project.
                      Da_Elf slaps WWX with a trout (for all those old mIRC people)
                        I've the same problem here with 2 machines. Both plugin.ini (in Max 9 & Local settings) end with V-Ray lines.
                        Any Clues?
                        Thanks
                          Originally posted by ren0 View Post
                          Any Clues?
                          Thanks
                          The lines must be in the correct order (the one about additional V-Ray plugins should be the last one).
                            Here is my plugin.ini:
                            [Help]
                            mental ray 3.5 Reference=C:\Program Files\Autodesk\3ds Max 9\help\mr_reference.chm
                            [Directories]
                            Digimation Plugins=C:\Program Files\Autodesk\3ds Max 9\plugins\Digimation
                            V-Ray main plug-ins=C:\Program Files\Autodesk\3ds Max 9\plugins
                            V-Ray additional plug-ins=C:\Program Files\Autodesk\3ds Max 9\plugins\vrayplugins
                            And the problem is still here.
                            • #15
                              Try removing the ;=; line and see if it works.
