SP3 Crashes too many times.
  • SP3 Crashes too many times.
    I have been using it since it was announced and I have had too many crashes.
    With SP2 VRay hardly ever crashed on mr.
    I don't know what the reason might be as it is not something that I changed that caused it.
    Nir
    3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
    have you tried uninstalling and reinstalling VRAY?
    Kind Regards,
    Morne
      The crashes happen when rendering final renders with a bit higther resolutions (ever at 1000 pixels it may crash)
      I rendered very big images prior to SP3 and it always did well. (4000-6000 pixels)
        Maybe ur using new max, where bitmap pager always on, so it might lead you to a problem
        I just can't seem to trust myself
        So what chance does that leave, for anyone else?
        CG Artist
          MAX installation is very old and works laike a charm
          but I will check the bitmpa issue.
          although the scene is NOT bitmap oriented as I have scenes with many big bitmaps
            Can you send me a scene that crashes to vlado@chaosgroup.com so that I can take a look at what may be wrong?
              I will
              Do you need the bitmaps as well ?
              Nir
                If it still crashes without the bitmaps, I don't need them.
                Best regard,
                  I sent you the files but as I am in a hurry - I re-installed SP2 and the scene does not crash.
                  NIR
                    Yep, I got it and I'll be looking at it.
                      Hi
                      Can you tell me good news ?
                      I am still waiting for a solution to my SP3 crashes (I am using SP2 in the meanwhile)
                      NIR
                        I'm still working on it.
                          Thanks for the prompt reply - you are working too hard !!!
                          Nir
                            So actually I found the reason for this. The problem has been there also in all previous versions of V-Ray, but became apparent only in SP3 for some reason. There will be an update going out next week when we also release V-Ray for 3ds Max 2010.
