Just testing EnvirontmentFog, but got a problem.
Made a small test scene with a noise map with animated phase in the density slot and rendering frame 0 took less then 1 second rendering frame 1 takes 22minutes.. basically all frames except frame 0 takes ages to render.
I'm on WinXp 64bit max 9.0 sp1.
UPDATE: It's only when rendering single frames it's slow on everything beside frame0. If I render a sequence all frames are fast.
Help!
Help!
