EnvironmentFog and animated phase is slooooow
  • EnvironmentFog and animated phase is slooooow
    Just testing EnvirontmentFog, but got a problem.
    Made a small test scene with a noise map with animated phase in the density slot and rendering frame 0 took less then 1 second rendering frame 1 takes 22minutes.. basically all frames except frame 0 takes ages to render.
    I'm on WinXp 64bit max 9.0 sp1.
    UPDATE: It's only when rendering single frames it's slow on everything beside frame0. If I render a sequence all frames are fast.
    Help!
    www.suurland.com
    www.cg-source.com
    www.hdri-locations.com
    Yep, someone else reported it already. It is fixed now, but in the meantime you can use any other texture except the 3ds Max Noise one.
