VrayFur with Vray2SidedMtl invisible?
  • VrayFur with Vray2SidedMtl invisible?
    sp3 (possibly other versions).. not sure if this is a known limitation or not, but vrayFur does not show up in renders with a Vray2SidedMtl applied.
    is this something that's fixable?
    thanks,
    greg
    Dang dude, working at 9 on a Saturday night?
    I wonder if it is just broke or if your the first one to ever try it.
    the new vrayfastSSS2 mat is pretty fast, if your trying to get a translucent effect it might work for you.
    Eric Boer
    Dev
      sad isn't it? (there's no time in the budget for "test out vray"...) plus i have nothing better to do! what are you doing on the boards at 11 on a saturday night? you should be drunk by now.
      annyway... yeah, i ended up going with the fastsss2 for now. not sure how this will respond in animation, though.
      drop me a line sometime and let me know how everything's going. you're employed, right, so i don't suppose things can be that bad!
      greg
        Vray2SidedMtl really is for single sided meshes, like if you were to create some paper or a lampshade. So you right, it doesn't work because its not supposed to.
        But saying that it should still render..
        Natty
        http://www.rendertime.co.uk
          What about fur with flat normals, not sure if those are single sided or not?
          @greg yep should have been drunk instead of cruising the net, heh. After focus I only got about a week and a half off till I started at my new place, I should have milked the time off more.
          Eric Boer
          Dev
