Whenever I render in max2010 design, the VRay FrameBuffer is behind the 3ds max windows and toolbars. It is not possible to bring it back on top of the screen. Is this a known bug? And is there a workaround available?
VRay FB is not focused while rendering in max2010 design
I am having the same problem. The Vray frame buffer will not keep focus.
I'm using 3D Studio Design 2010 with latest hotfix, Vray 1.50.SP3a, 64 bit, Win XP
I have a dual monitor steup and the Vray frame buffer will not stay on top of any of the other dialog boxes like Render, Material Editor, Map browser, whatever. If I drag the frame buffer to the other monitor where the Max application is open , it disappears behind the Max window. This is making it very hard to work with!
I hope someone, maybe from Chaos, sees this thread and can offer a fix.
Can anyone else verify this problem?mark f.
openrangeimaging.com
Max 2025.2 | Vray 6 update 2.1 | Win 10
Core i7 6950 | GeForce RTX 2060 | 64 G RAM
Thank you for the reply. If I clear out the arch-design materials from the material editor then the Vray Frame Buffer holds focus correctly. Weird, but workable.
I guess there is no need to use the arch - design materials with Vray. Do I understand correctly that they are to be used with Mental Ray only?mark f.
Vfb
Me too... very frustrating that I have to keep the material editor closed.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- ​Windows 11 Pro
you understand that if you clear out all of the arch-design materials from the Material Editor, it works as before with no focus problem? Minor inconvenience vs. serious frustration.mark f.
If you use your second monitor to have the other dialog boxes open in this is still a problem. I have a dual monitor setup. One monitor has the main Max window, the other monitor has the command panel the Mat Editor, Render Setup, Map Browser and other dialogs depending on what I'm doing. The Frame buffer will not display on top of these unless the arch-design materials are cleared from the Material Editor or the Material Editor is closed.mark f.
We are reworking some portions of the VFB and we'll see if it fixes it. However I've noticed similar issues with max's own frame buffer and other dialogs also, so I don't have high hopes for it.
Thank you for your reply!mark f.
