Muddy shadows
  • Muddy shadows
    I have tried everything, but nothing is handling the noise in the shadows.
    I applied a material override so it isn't materials. The back of the car looks fine and some of the geometry like the garage door is good. HELP!
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    It looks like double faces or duplicated geometry.
      Double faces
      Yep, that was it. I have no clue how that happened. The file was fine two days ago and I didn't do anything to geometry. Oh' well.... at least it is fixed. Isn't there a script running around that cleans up double geometry?
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        MoonDoggie's script helps in some cases:
        http://www.scriptspot.com/3ds-max/find-coinstances
        Or you can try to increase the secondary ray bias to something like 0.1.
        Cheers
          Yeah it does help some of the time (if the objects are exactly identical), not just if two faces are overlapping. Good luck, it's possible with a script to go through every object/every face, but frankly it's too time consuming and the end-user wouldn't wait for the execution time. , to I usually just put a material override with a vraydirt in the diffuse slot, and self-illum to 100%, this reveals double faces quite well.
          Good luck,
          Colin
          Colin Senner
