keyboard typing delay with sp3a
  • keyboard typing delay with sp3a
    hi,
    when the spawner (sp3a) is running on the renderslaves typing on the keyboard
    (of the slaves)
    has a delay of some seconds. is that normal? running sp2 everything works fine.
    cheers, dirk
    keyboard delay
    Yes, me too. The fix was add your swaner as a service, but then my textures don't work.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      What if you use the "run as" tab and run it as the gui user ? most likely the system user doesnt have access to the network locations.
      Regards,
      Thorsten
        thanks a lot for the answers...
        hm, i'm pretty happy that my former problems with missing textures are solved and DR
        with sp3a works fine now. but tomorrow i will give it a try, starting the spawners as service.
        is there any other trick to avoid the delay if this won't work with the textures ?
        cheers, dirk
          For the textures to work, you just need to set up the service to run under a proper user account (not the system default one), and to use UNC path names.
            hdri
            Everything works for me know,but HDRI. When I remove the HDRI everything works great.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              yes the keyboard tapping is still a problem
              my wife complains all the time - till I told her (regretfully) how to shut down the dr slave.
              can this be fixed. What is the swaner service?
              Raj
                the "swaner service" seems to be the result of the typing issue
                i think he means the spawner.
                  I had the same problem for some time.. this hotfix from Autodesk fixed the problem when running 2009 and sp3
                  Hotfix – Autodesk 3ds Max 2009 – 2009.03.16
                  Haven’t upgraded to 2010 yet because I’ve only just got 2009 working well.... don’t need all the hassle again...
                  Cheers
                  Bromley
