i have the problem, that in the scene i work on at the moment, the scene is not transferred to the render server.
i used dr in my last 4 projects and everything worked fine. now i reuse one of this scenes where dr worked yet, i checked with asset tracking that all path`s are network paths, launch the dr spawner on both pc`s, enable dr and check that both pc`s are there in the server list(with correct id numbers).....
i also pinged my pc`s wizh each other to check the network connection.
but the scene is only transfered to the renderclient.
also remarkable: when i had problems with a renderslave before, i got an error message in the vraylog window, but now nothing is written there about the render server.
what am i doing wrong?
can the different number of cores be the cause for the problem?
render client: corei7(8 cores) , render server: xeon e5320(4 cores)
in light cache, number of passes i used 8
