Render slaves and saved IR/LC maps
  • Render slaves and saved IR/LC maps
    I am rendering a scene where we have pre-calced out the IR/LC maps to be used for the final renders. Everything works fine until we send the frames to render; for an unknown reason the render slaves will not load the maps. We have tried using UNC paths, mapped drives, and even copying to IR/LC maps to the slaves themselves without remedy. We have tried both Backburner and Deadline but have not been able to resolve this issue.
    Has anyone else come up against this issue before?
    ___________________
    joel lelievre
    www.intrinsia.net
    www.delicatemachines.com
    Do you see an error message in the V-Ray log file? If yes, what is it?
      Hi Vlado,
      initially we were getting missing irmap errors, so we copied them to each slave. The attached log does not indicate any missing maps errors yet the ir/lc does not get rendered.
      Here is a link to the text file: vraylog
      ___________________
      joel lelievre
      www.intrinsia.net
        Code:
        [2009/Oct/30|14:45:44]       Loading irradiance map from file "C:\cache\lights_v006.vrmap"...
        [2009/Oct/30|14:45:44]       warning: Error loading irradiance map: Error opening file
        [2009/Oct/30|14:45:44]       Retrying to load irradiance map (0)...
        [2009/Oct/30|14:45:44]       Retrying to load irradiance map (1)...
        [2009/Oct/30|14:45:44]       Retrying to load irradiance map (2)...
        [2009/Oct/30|14:45:44]       error: Could not load irradiance map
        [2009/Oct/30|14:45:44]       1 interpolation maps registered
        Something's Borked with the irmap...
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          Agreed Lele; something is definitely not working. It loads fine on my local machine; and my textures work without a hitch; as do the rendered exrs. I am at a loss to explain why the irmaps fail to load.
          ___________________
          joel lelievre
          www.intrinsia.net
            May give a whirl to a centralized location, close to where you save the EXR output, and use unc paths.
            May not work, but hey, it can't go any worse... (famous last words)
            Lele
            Disclaimer:
              why is it trying to load it from c:\ is this a networked drive?
              WerT
              www.dvstudios.com.au
                Hey werticus,
                our default setup uses mapped drives which the slaves can see/render to; usually it works without issue. When we ran into the irmap issue we tried UNC paths, and when that didn't work we copied the irmaps to the slaves, (in this case the C:/ drive), and tried that as well.
                ___________________
                joel lelievre
                www.intrinsia.net
                  Ah, there you go Joel, you already tried it out, i forgot about that.
                  Mh.
                  Lele
                  Disclaimer:
                    then perhaps they are not saving correctly in the first place. Can you look at the maps with the ir map viewer tool okay?
                    WerT
                      Yeah i checked the irmaps on each slave and they look ok... I just re-installed vray on the slaves and am testing it again to see what happens.
                      ___________________
                      joel lelievre
                      www.intrinsia.net
                        Happy to report that after re-installing Vray SP4 on the render slaves everything seems to be working properly. Thanks for the help everyone!
                        ___________________
                        joel lelievre
                        www.intrinsia.net
                          Ah!
                          Glad to hear it!
                          Lele
                          Disclaimer:
