bad buckets on certain materials
  • bad buckets on certain materials
    Hi
    This is a problem that I have been dealing with since SP3 and never got an answer:
    please look at the image:
    I use a simple VRay material for the windows elements and get some buckets rendering with different tones - Note that there is no map used in this material - just plain material.
    reflection is set to about 10 but other than thta - nothing
    I had thgis problem even with WARD and Phong in the BRDF.
    As you can see the other area were rendered OK.
    BTW - I only noticed this in a Birdseye view render and not in the view taken form a human eye level....
    NIR
    3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
    It should work if you disable the interpolation option. This issue is fixed in SP4.
      thx but where exactly is this parameter ?
      Is it in the material GUI or Vray's GUI ?
      EDIT: This was done in SP4
      Nir
        It is right below the reflection subdivs parameter in VRayMtl (it's labeled "Use interpolation").
          So should I use it in all of my materials ?
          I ask because I always use interpolation (as it quickens rendering)
          ALso - Are u saying that in SP4 the interpolation can be used as before ?
          NIR
            This particular problem is fixed in SP4, yes. However it might be better to wait a little until we release SP4a before upgrading.
              now that SP4a is released - was it solved ?
              I am hesitating to install SP4a.
              Regards
              Nir
