How to save and RPF animation image?
  • How to save and RPF animation image?
    hi everyone,
    I use for the first time the VRAYCAMERA et VRAY FRAME BUFFER for an animation.
    I can't figure out how to save each frame in RPF with the gamma, color etc I made in the vray Frame buffer.
    I though I only need to save as always in the common roll-out of max, but in Combustion2008 no color correction is apply, it remain as the "basic" image before any color/gamma/.. of the vray frame buffer. Witch is really not good.
    Any help would be great.
    I need rpf because I have to had Motion blur, Zdeph fog, Color Id correction...
    Thank a lot
    Olivier.
    you have to use the EXR format ... you get all the renderelements with it
    activate: render Vray image raw file and choose a name like: test_.exr
    all activated renderelmets will be inside the exr file
      in Fray FrameBuffer activate:
      "render to V-Ray image raw file" and choose a name like: test_.exr
      all activated renderelments will be inside the exr file
        Thanks,
        I just tested this solution, but I come across an other problem : inside Combustion the Image looks totally blown-out. try a gamma correction decrease but can figure out how to get it right.
        For now I trying separates files and a Combustion G-buffer builder. Not my favorite way to go , but seems good for now.
        any clue?
