HELP!!! weird samples in render
Yes, actually I just unchecked the reflections box under the material options and the dots go away. If I use the vray material wrapper like you suggest will I still get reflections but with no dots?
UPDATE: I just added the metal material to a vray wrapper material...and with the base material having the Trace reflection checked in the options roll out I still get the dots.
How can I fix this?Last edited by sfeely; 25-01-2010, 08:50 PM.
Did you try to lower the intensity of the vray light mat? I found that overbright vray lights cause dots.
These dots happen usually because of reflective/refractive GI caustics (when a GI ray goes through glass or reflection and hits a very bright object). Turning off reflective/refractive GI caustics may help in that case.
