Multimatte with glossy refractions
  • Multimatte with glossy refractions
    Apologies if this has been discussed before, but I couldn't find anything on the forum.
    Is it possible to have an object behind a glossy refractive surface appear in a multimatte?
    I can't get it to work here...
    Many thanks,
    Olly
    Set V-Ray class properties en masse with the VMC script
    Follow me for script updates: @ollyspolys
    It will work for a clear refractive surface if you set the "Affect channels" option to "All channels". If you want a glossy effect, you can perhaps add a tiny bump map to the material. I've made a note to implement this for glossy surfaces as well (we already have that working in Maya, shouldn't be a problem to get it in 3ds Max too).
      Thanks Vlado, great idea for a workaround.
      Another thing I just wondered: is it possible to have a an object's reflection appear in a multimatte?
