Split render channels dialog obscured
  • Split render channels dialog obscured
    This is something that has always bugged me, but never been a huge one: the "Split Render Channels" part of the render rollout is always cut-off and I can't resize the dialog box to show it. Is this the same for everyone, or is there some way to fix it?
    (see attached for screen cap)
    Thanks!
    b
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
    Hi Brett,
    I have the same problem here - and it's been this way for quite some time.
    I am also looking for a solution.
    greetings
    Michael
    http://www.frame3d.de
      Yes, I´m really hoping for a fix for this... as you say it´s not a huge issue but its very annoying when you open up an old file and you cant see where you are going to save your render. I know you can see it in the asset tracker but come on, it cant be a difficult thing to fix.
        never happened here, I see the whole box alright. might be a max/vray version combo? I'm on 2010 and sp4a here.
          Its not a bug. The box is just too small. If you have a long filepath in that little box it gets cut off.
            Yep, I've made a note to correct it.
              well, I didn't get the problem at first. happens the same here with long path names.
                Oh, thanks vlado!
                While you´re at it, is there anyway to make vray remember the folder you are saving to? It would be great to have it start in that folder when you click "browse..."
                Thanks again!
