Licensing problem
  • Licensing problem
    Hello.
    I've just reinstalled windows 7 64, 3d max 2011, vray and vray rt on my two machines.
    I've configured a home group in windows 7 for the net.
    Workstation1 (192.168.1.100) has the dongle plugged acting as license server. In this machine everything work fine.
    The license server in this machine point to localhost:30304
    In workstation2 (192.168.1.104) I`ve configured the license to point to 192.168.1.100:30304. But this not seem to work. I obtain the kown "couldn't obtain a license" message in 3d max.
    But more extrange is this message I obtain whe I try to render throug backburner.
    What can I do?
    www.gaell.com
    Sorry, I've just realized that the problem was the dammed windows firewall.
    Everything working fine now.
    www.gaell.com
      Ok, glad it works now
        Didnt want to start a new thread. Im having problems with my license too. It occasionally spits out a "couldn't obtain a license". I have turned off all my Windows 7 firewalls. This happens from time to time. (Also got DR problems with missing textures from the render slaves too). All works fine in windows XP 64.
        Regards
        Steve
        My Portfolio
          Can you tell me what is the error code after the "could not obtain license" message?
            Error code 1000
            Regards
            Steve
            My Portfolio
              Do you get a delay before this message comes out? I've been able to reproduce this a few times here, but I'm not sure it's the same problem.
              You can also try restarting the license server and see if this helps.
                Yes, I think there is a delay.
                I have the license server running as a service at the moment...so would I have to unregister it and then re-register and start it ?
                Regards
                Steve
                My Portfolio
                  No, just go to the Services applet in the Control Panel, find the V-Ray license service, right-click it, select Stop, and then Start.
                    ok done that. As I said, the license error only comes up from time to time...probably once or twice every week. Shall I start another thread regarding my issues with DR and maps ?
                    Regards
                    Steve
                    My Portfolio
                      They might be related; there could be something strange in Windows 7 regarding network connections. Other than Windows firewall, do you use any antivirus software?
                        Yes, I use AVAST. Ive always used it with windows xp and had no problems. By the way, now Ive restarted the service and sent a new image to render, DR is now saying "192.168.0.xxx is not responding", and then, "render complete" even though my main workstation is still rendering. I have all 4 render slaves with the same message.
                        Regards
                        Steve
                        My Portfolio
                          I just checked the VRAY log on one of the render slaves and it said error code -209 (could not obtain license).
                          Regards
                          Steve
                          My Portfolio
                            The only way I can get DR working properly again is to restart my main workstation. Pain in the arse !
                            Regards
                            Steve
                            My Portfolio
                              Ok, odd; next time you get this error, can you open a web browser and type
                              Code:
                              http://licenseserver:30304/getlog
                              where licenseserver is the IP address or name of the machine where the license server is running, and send me the resulting log file to vlado@chaosgroup.com?
