Has anyone actually got Vray 2.0 Beta Working
  • Has anyone actually got Vray 2.0 Beta Working
    I have installed and sent my file to chaos,received the update file for my dongle.Everything applied fine.
    I still have license error but RT works fine..
    Removed the installation file and wibu installer..Now when i try to install fresh using Vray 2.0 wibu i get errors as thought its missing something with the Vray 2.0 wibu key installer...
    Anyone got further than me ?
    There's a thread right below yours containing the same license problems
      There was a wrong version of the license server in the installation. I'm uploading the fixed installations now. Apologies for the inconvenience.
        So builds should be now up on the site with the correct license server; again sorry for the inconvenience.
          Vlado..I have downloaded the revised Vray 2.0 Beta download but im still getting Wibu Key error..
          Do i have to send another file to Chaos since this is a newer fixed installer and then apply to the dongle, i already applied the file that was sent earlier this morning to me
            Which WIBU-KEY error?
            best regards,
              Wibukey 250897:7758101 Failure reason : Wibukey API error occured (error17)
                Works now! Are there any Helpfiles anywhere yet? Don't get the Lens Effects stuff working =/ , and i get crashes (BPTracer) and errors with the Lightmeter
                [edit] Also crash when trying to create a Stereoscopic helper
                  Hm, all of these things work fine here. Which 3ds Max version are you using? Is it possible that something has remained from a previous V-Ray installation?
                  The help files are here (there is also a link in the Start menu): http://www.spot3d.com/vray/help/200R1/
                    I'm using max2010x64 on win 7. It happens very randomly, so i will try it on another workstation this evening. I uninstalled all vray plugins so it should be clean.
                      Vlado all works fine now after a few installs...
                      The Vray Lens Effects are absolutely fantastic..work a treat
