VRay 2.0 beta domelight weirdness
  • VRay 2.0 beta domelight weirdness
    Opening a vray 1.5 scene which is lit by an exr in a vray dome light in vray 2.0 beta and hitting render results in:
    when it should look like:
    changing to a vraysun & sky in vray 2.0 beta gives a result that looks right at least.
    Any ideas?
    (happens on other scenes too)
    www.peterguthrie.net
    www.peterguthrie.net/blog/
    www.pg-skies.net/
    Hi Peter,
    What version of max are you using?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      2009 SP1 x64
      www.pg-skies.net/
        Peter,
        I just tried to reproduce your problem.
        The mapping options for HDRs (if you are using the VRayHDRi loader) have changed in 2.0.
        If you switch to "spherical" mapping type that should work as expected.
        Chris Jackson
        Shiftmedia
          Peter i have just opened an old 1.5 scene i have using a Dome Light light and one of your EXR's and its rendered fine.
          2011 and XP64
          Added onto this..It rendered fine for the lighting but i must say the glass is completely different to how it was with Vray 1.5. Its as though the glass is now completely see through and looks completely different to the previous renders i did with 1.5..
          I wonder if this has anything to do with using a colour correction mod ??
            thanks guys, I just tried rendering my scene with the exr in the environment map slot instead, and it worked fine. Seems to be the vraylight that is causing the strange result.
            exr in env slot:
            exr in dome light:
            are there any vraylight settings that differ from vray 1.5 to vray 2.0? (I havent changed anything, just opened an old file and hit render)
            www.pg-skies.net/
              hmmmm that is a bit odd.
              There have been some changes to the DMC sampler.
              http://www.spot3d.com/vray/help/200R...ate_to_1_5.htm
              What happens if you start the scene fresh with 2.0?
              Chris Jackson
              Shiftmedia
                Interesting; Peter can you send me that scene to vlado@chaosgroup.com to see why is the difference?
                  max2009 file on its way to you Vlado.
                  After the last test, I thought I'd try it with just a vraycolor instead of the exr, same result.
                  Hoping its something simple like me not having installed properly, although I have reinstalled many times and made sure no old versions were left in the folders.
                  www.pg-skies.net/
                    ha! changing the photon emission radii from 100,150 to 10000,15000 in the vraylight options seems to fix it !?!?!?!?!?!?!?!?!?
                    www.pg-skies.net/
                      Ouch, thanks for the pointer, fixing now...
                        thats weird...hows photon emissíon radius related to this ? ....not on vray 2.0 yet but this is strange
                        Martin
                        http://www.pixelbox.cz
                          Sounds like your units/scene scale has changed
                          Chris Jackson
                          Shiftmedia
                            It should not be related of course... it's a bug - it was meant to be the dome light ray distance parameter, not the photon emission one
                              glad its cleared up, now I can move on to playing with the new things!
                              www.pg-skies.net/
