Broadcasting NOTIFY_RENDER_PREEVAL last marker at .\src\vrenderlight.ccp, line 152
  • Broadcasting NOTIFY_RENDER_PREEVAL last marker at .\src\vrenderlight.ccp, line 152
    http://www.3delicious.de/spielwiese/...IGHT-ERROR.jpg
    i ma having this error wirh vray 1.5 sp5 in max 2010-64 bit under windows7-64.
    It started when i added a VRayAmbientLight to the scene that already contained a VRayLight set to Dome and a direct light as Sun. I switched the dome light off and the ambientlight on and back and it started to happen every time.
    The original scene contains a Poser Character brought into Max with PoserFusion that then was cached with SuperMesher since PoserFusion causes nothing but trouble and crashes.
    What does that error mean?
    I attached a stripped and collapse scene file here
    http://www.3delicious.de/spielwiese/..._Test_AS02.rar
    Thanks in advance!
    Ansi
    Anselm von Seherr - Thoss, incendii VFX www.incendii.com
    any news on this one?
      my scene wouldn't render, please help anyone...
        Looking at it now...
          Hm, I have no problems rendering the scene. Judging by the fact that it's called "Multiscatter..." does it mean you are using multiscatter with it (doesn't look like it as I didn't get a warning about missing plugins). Does it work if you remove the MultiScatter plugin?
            it does here, multiscatter seams to be the problem indeed. however i need it to populate the scene
            thanks for looking into it!
            ansi
