OK after a long night - I can tell you nothing helped.
I tried everything -
I copied all the maps to each of the slaves using the Resource Collector.
I tried LC and IR seperately
Restarte
Please try to set your regional settings to use "." as a decimal symbol, instead of "," on all of your machines.
Do you have any texture in the environment? Can you disable the sky and set the Environment to white to see whether the issue will persist.
Make sure you have "Restart slaves on render end" option enabled.
Do you have the GI generate/receive multipliers changed for any objects in your scene (through the V-Ray object properties dialog)?
Zdravko Keremidchiev
Was just having the exact same problem with Solidrocks. It was happening when I had my materials' reflectance being interpolated in combination with using DR. After trying almost every setting on and off i finally just hit the "reset solidrocks and vray" button and now its gone.
Unfortunately I still have no idea what setting was causing the problem.
