Viewport (with safe frames) does not match render
  • Viewport (with safe frames) does not match render
    Ive attached an image to show you what I mean. Not had this issue before..
    Regards
    Steve
    My Portfolio
    Is there distortion on in vray camera?
    Lasse Kilpia
    VFX Artist
    Post Control Helsinki
      No distortion on for both the camera or camera settings (render rollout).
      Regards
      Steve
      My Portfolio
        Anyone ? It also happens in the standard max frame buffer.
        Regards
        Steve
        My Portfolio
          Can you get me a scene for this to vlado@chaosgroup.com?
            Have you tried switching to a different renderer? As it might not be a Vray specific issue.
              With the standard renderer (still looking through the vray physical cam) it renders fine.
              I'll send you a stripped back scene now Vlado.
              Thanks
              Regards
              Steve
              My Portfolio
                This is because of the vertical offset of the physical camera. Unfortunately we could not get the viewport to match the correct result from the rendering for this parameter. In this case, the viewport is wrong.
                  So, is this something that will be fixed ? or is this something that I need to work round ?
                  Regards
                  Steve
                  My Portfolio
                    We spent quite a bit of time trying to fix it, but we couldn't get the viewport to display what we wanted. We will probably come back to that again at some point.
                      Ok no problem. This is something I havent noticed before until I did this very long landscape style render.
                      Regards
                      Steve
                      My Portfolio
                        Any chance a fix is coming for this?
                          I believe it is fixed in the latest nightly builds.....
                          Maxscript made easy....
                          davewortley.wordpress.com
                          Follow me here:
                          facebook.com/MaxMadeEasy
                          If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
                            Yes, like Dave pointed out this is already fixed in the nightly builds and for the next service pack.
