transparency issue
Looks like your transparency map isn't 100% black in the areas it should cut things out. Are there reflection settings on that material too? Would it be that the transparent parts of the map are still reflective? Is the entire sign casting a shadow?
do you have the glass as one object then the logo on another object overlaid over the glass?
Originally posted by joconnell View PostLooks like your transparency map isn't 100% black in the areas it should cut things out. Are there reflection settings on that material too? Would it be that the transparent parts of the map are still reflective? Is the entire sign casting a shadow?
Originally posted by Da_elf View Postdo you have the glass as one object then the logo on another object overlaid over the glass?Last edited by on3ddesign; 13-02-2011, 09:48 AM.
